Where can i download the latest SMC
Unfortunetely its not available for download on the website due to its size. It is only available throught the CD that comes with the appropriate player. C100,C200,E200,E200R for example.
If you have an older verion of the media converter you can use the check for updates feature.
If you do not have the original disk you can contact SanDisk Technical support and they can mail you a copy.
Thanks for the informations guys
