The attribute ID is the first column and attribute name is the second column. The question is what do these attributes mean because their values are changing, which means that the firmware is finding a condition and updating the counters. Here is the full set of S.M.A.R.T. attributes:
Unknown attributes are typically either vendor specific or unsupported attributes. Either way they are not an attribute that affect the overall life span of the device.
yeah, these attributes are most likely vendor specific and firmware is definitely changing them. So, someone at Sandisk knows what values are being published in those counters.
Does anyone from Sandisk monitor these forums? do you know what these attributes mean?
Check out the post above. The SMART attributes are not useful because they are named as Unkown. If they were named properly with better names, I would not be posting here… The information there is definitely changing, so the firmware is exposing those counters. I just don’t know what they mean.
