With a bit of research I started filling up this SMART attribute name list for the Sandisk Extreme II SSD with Marvell 9178-based controller. It appears that attributes are grouped in a logical manner, which should help figuring out what they mean. The [?] symbol denotes that SanDisk does not provide information about those attributes in the ToolBox or anywhere else, and that therefore they are my own’s best guess through observation.
Generic SMART parameters
05 - Retired Block Count [1 block = 4 MB]
09 - Power On Hours
0C - Device Power Cycle Count
Interface-level counters? (basing on SMART parameters for Marvell-based drives from other manufacturers)
A6 - [?]
A7 - [?]
A8 - [?] [This slowly increases as Host and NAND writes increase, but it does not seem to be linearly correlated with them]
A9 - [?]
Internal-level counters
AB - Program Fail Count
AC - Erase Fail Count
AD - [?] Average Block-Erase Count [P/E cycles]
AE - Unexpected Power Loss Count
BB - Reported Uncorrectable Errors
C2 - Temperature
D4 - [?]
Usage statistics - Internal
E6 - Life Curve Status [No idea about what this means. So far, its raw value increased by 3 for each block-erase count event]
E8 - [?] Percent Lifetime Remaining [%]
E9 - [?] Lifetime NAND Writes [GiB]
Usage statistics - Host
F1 - Lifetime Writes to Host [GiB]
F2 - Lifetime Reads from Host [GiB]
F3 - [?]
Micron/Crucial provide something like this, which helps big time:
M500: http://www.micron.com/-/media/Documents/Products/Technical%20Note/Solid%20State%20Storage/tnfd21_m500-mu02_smart_attributes.pdf
M550: http://www.micron.com/-/media/Documents/Products/Technical%20Note/Solid%20State%20Storage/tnfd22_m550_m510_smart_attributes.pdf
Since they’re based on the same controller, many of these parameters are exactly the same. However we cannot be sure until SanDisk confirms and/or provides similar documentation. Please help!
