Sir my pen drive write protcted not format
sir my pen drive write protcted not format
Description: [F:]USB Mass Storage Device(SanDisk Cruzer)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 200mA
USB Device ID: VID = 0781 PID = 5530
Serial Number: 20060878310578C364E6
Device Vendor: SanDisk
Device Name: Cruzer
Device Revision: 0126
Manufacturer: SanDisk
Product Model: Cruzer
Product Revision: 1.26
Controller Part-Number: Unknown
this support frimwer link send me…
@basu
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
If your SanDisk Cruzer USB is write-protected and won’t format, try these fixes:
Check for a lock switch – Make sure it’s off.
Use Command Prompt – Open diskpart, select your USB, and run attributes disk clear readonly.
Edit Registry – Set WriteProtect to 0 in StorageDevicePolicies.
Update Firmware – Check SanDisk’s support page.
Faulty Drive? – If nothing works, the USB may be damaged. Contact SanDisk or replace it.
Did you get an error prompt like ‘Your SD card is locked’? Follow the steps below to run DiskPart command lines to strip the write protection from your pen drive.
Besides, you can also try connecting your pen drive to another Windows computer and changing file permissions in the Properties. Alternatively, use the Registry Editor to disable write protection.
Read also: How to Remove Write Protection from an SD Card
