Shuffling between Internal memory and external memory SD card
Does the Sansa Clip+ shuffle between the songs on the internal memory and the external memory SD card; or are they considered different as far as playing the songs stored on the internal and external SD card? I have 4GB Clip+ with a 8 GB external SD card. Does that make 12GB total? Or do I need to switch from internal to external manually to hear songs loaded on external SD card?
@dohar9 wrote:
Does the Sansa Clip+ shuffle between the songs on the internal memory and the external memory SD card?
Yes.
In theory, yes. In actual pracitce though it will probably be closer to 10.75 to 11GB.
No. the player will play from both memory locations seamlessly when using Shuffle mode.
Thank you, just what I wanted to hear:smileyha:
