I have just bought a San Disk Sport 8gb SDMX24. I also bought a memory card . I have added music to the external memory card but how can I just select Shuffle that plays songs from both the internal memory and external memory card.At the moment all I can do is chose either shuffle what’s on one or the other not both or am I missing something?
The Clip sport treats internal and card memory separately. I suggest getting a larger card if you need it, and keeping all songs on card memory. Keep in mind though that the player database will only support up to around 2,000 songs on card memory(plus up to 2,000 on internal memory). Since 32GB cards are so cheap now, many will get one of those. Get a class 4 card, as using a faster card might give plenty of problems.
