I don’t know that I really need this tool. Will some one tell me if it is worth having. I see some problems here on this forum. I like the Sandisk Drives but if the software is not good then I don’t need it. I think I can find all the performance info I need elsewhere.
Thanks
its the only way to get any FW update. If you are up to date on the FW you dont really need it.
How would I know the firmware version without the Dashboard? Does Microsoft also provide firmware for a device like this?
Thanks
No, only Sandisk Provides the firmware for this device!
And Yes you Should install it!
Thanks, I think this all answers my question now. Don’t know who to give the “Solution” to here? It was a joint effort between McHunter and drlucky.
No problem . . . I added drlucky’s post as a solution as well. Credit where credit is due.
Thanks
And how can he see if his firmware is uptodate without the Tool?
Thanks for the clarification.
I was in two minds to install or not. Thanks for the answer.
essayservice
essayservice
