When I am copying files to a SecureAccess 2.0 vault on my 128GB Extreme, it goes along fine for a bit and then I get a popup error which says: Cannot open file for write F:\SandiskSecureAccess Vault{…}.dat Error:The directory or file cannot be created. When I click OK, the copy process stops and it ends. I have tried reinstalling SecureAccess 2.0 after deleting everything. I have formatted the flash drive as FAT32 and reinstalled SecureAccess but none of this has helped. Any ideas? Thanks.
Hi, are you still interested in recovering your data or you got rid of your Vault and/or USB Stick?
I can help you save it if you are still interested in recovering your data.
I am having the exact same problem.
SanDisk 128GB Extreme Pro using SanDisk SecureAccess V2.0.
Was working fine for the first two weeks, but now I get the following error when coping files into MyVault.
"Cannot open file for write D:\SanDiskSecureAccess Vault{4ce1b97b-a5a7-4457-9898-cc0390604b44}.dat
Error: The directory or file cannot be created"
Properties (general tab)
Type: Removablke Disk
Filesystem: FAT32
Capacity: 128,004,390,912 bytes 119GB
Used space: 4,914,741,248 bytes 4.57GB
Free space: 123,089,649,664 bytes 114GB
I am having the exact same problem. SanDisk 128GB Extreme Pro using SanDisk SecureAccess V2.0.
Was working fine for the first two weeks, but now I get the following error when coping files into MyVault. "Cannot open file for write D:\SanDiskSecureAccess Vault{4ce1b97b-a5a7-4457-9898-cc0390604b44}.dat
Error: The directory or file cannot be created" Properties (general tab)
Filesystem: FAT32
I know it won’t help you with any files you’ve written from a Mac or Windows computer, but you might consider using the ecryptfs system, in the .
see: mcdvoice
I fail to see how a spam link to a McDonald’s survey site will help or have any relevance to this thread. ![]()
Were you able to find any working solution yet?
If yes can you please help me out as I have similar issue and not able to solve it
its getting very frustrating now!
