SD Card Suddenly not found by phone or computer
My SD card was working perfectly in my LG Optimus L90 yesterday and connected to my HP Windows 7 laptop without any issues just 2–3 days ago. However, today, when I tried accessing media on my phone, it showed nothing. I checked the phone settings, and it stated that no memory card was detected. To rule out a phone issue, I tested SD cards from three friends, and all of them worked fine on my phone, so the phone itself isn’t the problem.
Next, I inserted my SD card into my laptop, but it didn’t recognize it either. In contrast, my roommate’s memory card was instantly detected and opened on the same laptop. I also tried using the Device Manager, but my SD card wasn’t listed, nor did ZAR recovery software detect it.
What steps can I take to recover the data, particularly a crucial video I need by next week?
Hi @Kizie
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
Since your SD card isn’t detected by your phone or laptop, it may have physical or logical issues. Check Disk Management on your laptop to see if it appears and try assigning a drive letter. Test it with another card reader or PC to rule out hardware issues. Running chkdsk might fix minor errors. If nothing works, try data recovery software to recover your data.
I found it expedient to have a USB multicard reader on hand in case of problems
USB port issues and card reader damage should be the first thing you should check. If there’s no problem, your SD card might be logically damaged or corrupted. Try following solutions:
  1. Run CHKDSK
  2. Change the drive letter in Disk Management
  3. Update SD card driver
  4. Format the SD card
    If you need more help, check this guide. This includes the fixes and recovery plan.
Since Device Manager and recovery tools like ZAR don’t detect it, the card’s firmware or memory chip may be damaged. First, test the card using a dedicated USB card reader and check if it appears in Disk Management as unallocated or RAW. If detected, create a sector-level image with tools like ddrescue or Stellar Imaging to avoid further damage, then try to recover the files using PhotoRec or Stellar Photo Recovery.
Since your SD card isn’t detected by either your phone or laptop, most recovery tools won’t be able to access it. If you already have a backup from before, you can restore your files from that without worrying about the card. Otherwise, professional data recovery services are probably your best bet.
Don’t freak out if your computer or phone suddenly can’t locate your SD card. Usually, corruption, incorrect ejection, or file system errors cause this. First, try using a different card reader or checking the card in a different device. Avoid formatting it if it hasn’t been found yet, as this could permanently delete your data.
Use a trustworthy data recovery tool like BLR Data Recovery Software instead. It facilitates the safe recovery of documents, images, and videos from corrupted or hidden SD cards. Even if your device doesn’t recognize the memory card, the tool thoroughly scans it and can restore lost data with a few clicks.
First, rub the gold contacts gently with a pencil eraser and then reconnect the card to your computer and see if it gets detected. If issues persist, assign a new drive letter in Disk Management, run the CHKDSK command to repair errors, and utilize data recovery software before reformatting.
Also read: How to Fix SD Card Not Showing up in Windows 11/10/8/7
I ran into this exact situation a few months ago. Since your friends’ cards worked in your LG Optimus and your roommate’s card worked in your laptop, the issue is definitely isolated to your SD card’s contact connection or file system layout. Before writing off that crucial video, try these steps:Hardware Bypass: Clean the metallic pins with a Q-tip and isopropyl alcohol. Then, avoid the built-in laptop SD slot—use a USB external card reader plugged directly into a USB port. Built-in readers on Windows 7 often fail to detect corrupted partition tables. Deep Scan for Recovery: If Windows detects the drive even without a assigned letter, run EaseUS Data Recovery Wizard right away. It’s significantly better at bypassing unreadable/corrupted partition headers than Recuva or ZAR to pull out raw video files directly. If it won’t detect on any external USB reader, a local recovery lab is your last resort.
I have several machines with SD card slots, they work fine. I also have a USB box for assorted antique cards and while old it also works fine
