Hi… Iam a photographer… After the shoot I insert the memory card to the system using card reader… but the card isn’t detecting… only the name of the card is visible…(Like- removable disk)… but it not opening… no card size is also showing… what should I do?
Hi @NaveenKumar
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
The SD card file system is not supported by the phone . SD card has a file system error or contains bad sectors. SD card driver is outdated. SD card is damaged or corrupted. ![]()
If your SD card is not being recognized by your phone, it may be in an unsupported file format or damaged . Try using a new SD card instead. Try force restarting your device. Restarting may resolve the issue of your device not recognizing your SD card ![]()
Ok, thanks.
Your memory card might have become corrupted or the card reader is malfunctioning. First, try using a different card reader or testing the card on another computer to rule out a reader issue. If the problem persists, you can try using disk management tools like CHKDSK (Windows) or Disk Utility (Mac) to repair the card. If it’s still not recognized, data recovery software might help retrieve files. As a college student, finding reliable help for assignments is always a challenge. This paperfellows.com service was a real lifesaver for me. The professionalism and timely delivery exceeded my expectations. The quality of the content was exceptional, with detailed research and clear writing. It made a huge difference in reducing my academic stress, and I’ll definitely rely on them again for future projects.
There could be an issue with the memory card’s file system or possible corruption. Before proceeding with the advanced SD card recovery methods or formatting your SD card, there are many easy fixes that you can try.
Fix your SD card with Windows error-checking tools, or disk management. This article can help you with the manual fixes and you can fix your memory card not detecting issue, How to Fix SD Card Won't Read /SD Card Cannot Read error
Sometimes, the problem may be with the USB port or card reader itself. Try using a different USB port or card reader to see if that fixes the issue. You can also try upgrading the drivers, assigning a new drive letter, or reformatting the SD card.
I hope this blog helps you resolve the ‘SD card not showing up’ issue.
There are several reasons why your SD card might not appear on your Windows computer. Some possible causes include a poor connection, corrupted or outdated SD card drivers, a missing drive letter, a corrupted or unrecognized file system, or physical damage to the SD card.
To resolve this issue and make your files accessible, try the following steps:
- Ensure the SD card is properly connected to your computer.
- Unhide any hidden files on the SD card to make them visible.
- Use Data Recovery software to recover any lost or deleted files from your SD card.
- Repair minor issues with your SD card using Disk Management or Disk Utility.
- Format the SD card to ensure it is compatible with your computer.
If you want to dive deeper into the details and learn how to fix the issue more easily, you can refer to this how-to guide:
How to Fix SD Card Not Showing up in Windows 11/10/8/7
