Not sure if this is right place to post. I bought a Sandisk Extreme SD Card 16GB and have been using it with my Nikon camera for still pictures. I tried transferring the photos to my Windows 10 Notebook but despite repeated tries, the card was not recognised.
Try some trial versions of recovery softwares (ex.: Easeus, R-Studio) to proof that the card is readable or not. If yes, you can pay for the software’s full version. If not, try Googling for a data recovery company in your surroundings who work with the chip-off recovery method. It have costs (especially for monoliths, like mini and micro SD cards), but this is the only way to bring back the valuable memories.
First of all, you should ensure the SD card is well connected.
In detail, you can do these things
Gently wipe the metal contacts of the SD card with a dry and clean cloth.
Dusting the slot of SD card reader or adapter, or simply replace it.
Use another USB port on your computer to connect the SD card adapter.
Secondly, you may have to go into the Windows Control Panel, Devices, and uninstall the SD Card Reader, and then reinstall it. I had that issue with a previous computer, and I believe it has something to do with doing a manual disconnect (safely eject?) before you physically remove the card.
If Windows isn’t detecting your memory card, try these four steps to fix it:
1. Refresh the Drivers:
Right-click the Windows Start button and open Device Manager. Look under Disk drives or USB controllers, right-click your SD card, and select Update driver. If that fails, click Uninstall device and restart your PC to force Windows to reinstall it.
2. Change the Drive Letter:
Windows might just need help labeling the card. Right-click Start, open Disk Management, and find your card in the list. Right-click it, select Change Drive Letter and Paths, and assign it a fresh, unused letter (like M or Z).
3. Repair File Errors (CHKDSK):
Press the Windows Key, type cmd, and open it as an administrator. Type chkdsk E: /f (swap E: out for your actual SD card letter) and hit Enter to let Windows automatically patch internal file system glitches.
4. Extract Data and Reformat: If nothing else works, your file structure might be corrupted. Use a data recovery tool to backup your files first. Once safe, go to This PC, right-click the drive, and hit Format to clean the card completely. Read also: How to Fix SD Card Not Showing up in Windows 11/10/8/7
