SD card is not working anymore
I was filming with my camera when suddenly I received a notification to insert another SD card. I removed it and inserted a different one. Now I can’t access anything from my SD card anymore. Neither in my camera or in my MacBook is the SD card not usable. Could someone help me recover my data :frowning:
It sounds like the second SD card you inserted might have been incompatible with your camera or it could have had some issues. I would suggest that check the compatibility and format it correctly because it can happen if the card is formatted in a way that your camera doesn’t support or if it’s damaged.
Read here for more information, Troubleshoot: SD card undetected issue - Files by Google Help
Also, this article can help you fix the SD card not showing up error.
Losing access to your data can be distressing, but there are steps you can take to attempt data recovery from your SD card. Here’s what you can try:
  • Check the SD Card Slot: Sometimes, the issue might be with the SD card slot itself. Ensure that there’s no debris or dirt in the slot by blowing gently into it or using a can of compressed air. Insert the SD card again to see if it’s recognized.
  • Try a Different Card Reader: If you’re using an external card reader with your MacBook, try using a different card reader or inserting the SD card directly into your MacBook’s built-in SD card slot (if available). Sometimes, the card reader might be faulty.
  • Use Disk Utility (Mac): If your MacBook recognizes the SD card but you’re unable to access the data, you can try using Disk Utility to see if the SD card appears there. If it does, you might be able to repair it or extract data using Disk Utility.
  • Data Recovery Software: If the above steps don’t work, you can try using data recovery software like Disk Drill, PhotoRec, or EaseUS Data Recovery Wizard. These tools are designed to recover lost or deleted data from various storage devices, including SD cards. Follow the instructions provided by the software to scan and recover data from the SD card.
  • Professional Data Recovery Services: If you’re unable to recover the data using the above methods, you might need to seek help from professional data recovery services. These services have specialized tools and expertise to recover data from damaged or corrupted storage devices. Keep in mind that professional data recovery services can be expensive, so consider this option if the data is valuable and worth the cost.
  • Prevent Further Damage: Avoid using the SD card further until you’ve attempted data recovery. Continued use of the card might overwrite the existing data, making it harder to recover.
Remember that data recovery success isn’t guaranteed, especially if the SD card is physically damaged. However, trying the above steps should increase your chances of recovering your important data.
In such a case, the first step that you should take is to repair your SD card by using First Aid.
  • Open Disk Utility. You can find it by searching for “Disk Utility” in Spotlight or navigating to “Applications” > “Utilities” > “Disk Utility.”
  • In Disk Utility, you should see your SD card listed on the left sidebar. Select the SD card.
  • Click on the “First Aid” button in the toolbar.
Additionally, you need to check whether the SD card is infected with viruses. If the problem is due to compatibility, you can use Disk Utility to format the problematic SD card. The only thing you need to worry about are the files stored on the SD card. After formatting the SD card, all data will be erased.
You can consider using free data recovery software to get back your lost files. Generally speaking, these software tools are very effective until the data is overwritten.
It sounds like your SD card might have become corrupted. Here are some steps to try to recover your data:
  1. Check the SD Card on Another Device: Test the card on another camera or card reader to see if it’s recognized.
  2. Use Disk Utility (Mac): Open Disk Utility on your Mac to see if the SD card shows up. If it does, try running the “First Aid” feature to repair the disk.
  3. Try Data Recovery Software: If the card is still unreadable, you can use data recovery software like PhotoRec, Disk Drill, or EaseUS to scan for and recover files from the SD card.
  4. Format the Card (Last Resort): If recovery software doesn’t work, formatting the card may be necessary, but it will erase all data. Make sure to try recovery tools before formatting.
If you are unable to recover the data, you may want to consider professional data recovery services.
According to my experience here are few things you could try:
  1. Test the card on a different camera or reader. Sometimes it’s just a compatibility issue.
  2. Use Disk Utility on your Mac (look for “First Aid”) to check and repair the card.
  3. Try data recovery software like Disk Drill or Stellar Data Recovery—these can often retrieve files if the card isn’t physically damaged.
  4. If nothing works, professional recovery services might be worth a shot, but they can be pricey.
In the meantime, avoid using the card to prevent overwriting the data.
cards <= 32GB I use FAT32 and the >32GB I use exFAT for the broadest compatibility
Hey! I had the same issue before - turns out there could be a few reasons your SD card isn’t showing up on either your camera or Mac. Here’s what I’d suggest trying:
On Your Mac:
  • Try Disk Utility: Open Disk Utility (Cmd + Space > search Disk Utility) and see if the SD card shows up in the sidebar. If it does but it’s grayed out, try mounting it manually.
  • Check Finder settings: Go to Finder > Settings > General and Sidebar tabs, and make sure “External disks” is checked.
  • Use Terminal: You can also run diskutil list in Terminal to see if the card is recognized, but just not mounting.
If nothing works, the SanDisk card might be corrupted. You could try using a recovery tool to perform SD card recovery on your Mac first.
Hope that helps!
There are several reasons why the SD card is not showing up on Mac, such as an incompatible file system, outdated SD card reader drivers, logical errors on the card, or physical damage. To diagnose the issue, first determine whether the problem lies with the Mac, the SD card, or the card reader. You can test the SD card on another computer or restart your Mac to help identify the cause.
1. Check Finder and Desktop Preferences
  • Open Finder > Preferences > General, and ensure the “External disks” option is checked.
  • Next, go to the Sidebar tab and confirm that the “External disks” option under Locations is also selected.
  • Then, check your Mac’s desktop to see if the SD card appears.
2. Reset NVRAM/PRAM
Turn off your Mac. When turning it back on, immediately press and hold Option + Command + P + R. Keep holding these keys for about 20 seconds, then release them and let your Mac boot up normally.
3. Manually Mount the SD Card
If your SD card appears in Disk Utility but is greyed out, it means it isn’t mounting.
To fix this, open Finder > Applications > Utilities > Disk Utility, then select the SD card and click the “Mount” button in the toolbar.
4. Recover Data and Reformat the SD Card
Install data recovery software on your Mac, scan the SD card for lost files, and recover them to your Mac or another external drive. Afterward, reformat the SD card to restore its functionality.
I suggest a low cost USB card reader which can handle many card formats. This way it can help when the machine reader is at issue.
