A problem came up with my SD card while transferring files from my camera to my Mac. By mistake, the card was formatted before everything was copied, and now it’s completely empty. Nothing has been done to the card since, to avoid overwriting any data. Is it possible to recover formatted SD card on Mac? Any advice would be really appreciated
Noted: Tried using EaseUS and Disk Drill, but they didn’t scan the card properly and only showed files already on my Macbook Air.
Yes, recovery may still be possible if no new data has been written. The formatted SD card’s previous file structure often remains intact. Avoid saving anything to it, and try scanning it using other SD card recovery tools if you don’t have any backups. If that fails, a professional data recovery service could help.
It is highly possible to recover deleted files from a formatted SD card. Go and try the data recovery software first. In most cases, it is free to scan the SD card before fully recovering the deleted files.
Here is a list of best mac data recovery software you can try out:
A quick format on a camera or a Mac normally just wipes the file index, not the actual photo data. I would suggest go for Stellar Photo Recovery Mac software. This software can scan for raw file signatures like .JPG or .CR3 even after a format.
1). If the formatting was a quick format, and you are sure no new data has been written to the card, it’s definitely possible to recover files from it.
Camera SD cards often use FAT32/exFAT formats, which are relatively easy to recover.
Try other Mac recovery tools to run a deep scan, and save the recovered files to your computer. (Always recover to a different drive, such as your Mac’s internal hard drive or another external disk. Do not save the recovered files back onto the original SD card.)
2). If the SD card received a full format with data overwriting, it becomes difficult or even impossible to recover the lost files.
On Mac, a full format can happen if:
You used Disk Utility to erase the SD card: Erase > Security Options > Most Secure
You used a Terminal command that explicitly overwrote data.
Don’t worry, recovering your files is definitely possible, and your chances are very good since you didn’t use the card after formatting. When you format an SD card, the camera or computer usually just removes the file index and marks the space as available; your actual photos and videos often remain on the card itself until they get overwritten by new data.
To get your files back, you’ll need to use data recovery software on your Mac. I recommend trying a reliable data recovery tool. Just connect your SD card with a card reader, run a “Deep Scan” on it with the software, and then preview the recoverable files it finds, like this guide: https://www.youtube.com/watch?v=HMIVja0ALhg. Most of these programs allow you to scan and preview for free, so you can check if your photos are intact before deciding to purchase.
Don’t panic! Stopping use of the card was exactly right—your data is likely still there. The software failed because your Mac isn’t recognizing the SD card and scanned your local drive instead.
First, check Disk Utility to see if the card shows up. If not, try changing the card reader or USB port. Once recognized, make sure to select “External Drive” and grant permissions in the software to scan and recover your files!
If those two programs still get stuck, try PhotoRec (completely free and powerful for photos/videos, though the command-line interface is a bit hardcore) or Data Rescue.
Since you haven’t used the SD card after formatting it, you still have a reasonable chance of recovering the photos and videos.
A few suggestions:
First, verify that your Mac is actually detecting the SD card correctly. Open Disk Utility and check whether the card appears with the expected capacity. If it doesn’t, try a different card reader or adapter, as faulty readers can prevent recovery software from accessing the card.
If EaseUS and Disk Drill are only scanning your Mac’s internal drive, they’re probably not recognizing the SD card correctly. Make sure you’re selecting the SD card itself as the scan target.
You could also try PhotoRec (free and open source), which is often very effective at recovering photos and videos from formatted SD cards, even when other tools fail. Another option is BLR Data Recovery Toolkit, which is known for handling memory cards well.
If the card is showing signs of hardware failure or disconnects during scanning, create a disk image of the card first (if possible) and perform recovery from the image instead of the physical card.
One question: what camera was the SD card used in, and did you perform a quick format or a full format? That information can help narrow down the best recovery method.
