Hi All,
I’m new to the forum so please excuse my ignorance.
I already have a 4G & 8G Fuze (the original version) and am ready to order a 4G ClipZip after reviewing xcomments here. I also want to buy a SD card with the ClipZip which hopefully will work on my other Fuzes, but don’t know which to order. I saw something about 16G max being recommended by Sansa? (I use the players pretty much only for audiobooks).
I see both 16G and 32G Scandisk Ultra Micro SD cards on Amazon and they come with an adapter. What should I order?
Not sure what the drill is, but am I right in assuming that the adapter is for plugging the card into a computer but the card fits directly into the Fuze?
I also assume you download an audiobook to your computer, then with Overdrive Media Console “transfer” it to the card which in turn is plugged into the player?
Thanks for any advice or explanations,
Skipjack
