This issue is usually caused by a corrupted file system, outdated /faulty drivers, or logical damage to the SD card. When Windows cannot properly read the file system structure, it may display the error message “The volume does not contain a recognized file system.” To resolve this problem on a Windows computer, try the following solutions.
- Run the SFC (System File Checker) command
Corrupted or missing Windows system files can interfere with how external storage devices—such as SD cards, USB flash drives, or external hard drives—are detected and accessed.
Open Command Prompt as administrator
Run the following command:
sfc /scannow
Wait for the scan to complete, then restart your PC. This tool will automatically scan for and repair corrupted system files.
- Use Windows built-in error checking tool
Windows includes a basic disk repair utility that can detect and fix minor file system errors.
Open File Explorer → Right-click the problematic SD card and select Properties → Go to Tools → Error checking → Check
If errors are found, Windows will attempt to fix them automatically.
- Run the CHKDSK command
CHKDSK can repair minor file system issues and scan the SD card for bad sectors that may be causing read errors.
Run the command below (replace X with the actual drive letter, such as F):
chkdsk X: /f /r
The /f parameter fixes file system errors, while /r locates bad sectors and recovers readable data.
- Update the USB or storage driver
Outdated or corrupted drivers may also cause Windows to incorrectly identify the SD card’s file system.
Open Device Manager
Expand Disk drives or Universal Serial Bus controllers
Right-click the related device and choose Update driver
After updating, unplug and reconnect the SD card
- Recover important data and reformat the drive
If the file system is severely damaged, repair attempts may fail. In this case, recovering your data should be the priority. Use reliable data recovery software to retrieve important files first. Once recovery is complete, reformat the SD card to a compatible file system (such as NTFS or exFAT) so it can be used again.
Also read: Fix The Volume Does Not Contain A Recognized File System in Windows
