Hello, my first post and I can assure you a real novice so I need ‘simple’ advice and instruction.
I want to save the things I have recorded, but when I connect my fuze to the pc it wipes them off the voice part and puts them in the songs section. The first time this happened I found, when I tried to play them it skipped through each one very quickly without playing them then went on th the next available track.
I recorded again and the next I connected to the pc it placed the recordings following the first ones, if you get what I mean, so I have 1-9 from the first time that just skip through and then 10-18 but I can play these.
The questions I have are
1 how can I properly save the recordings to my fuze
2 can I put them in a playlist and how
3 how do I rename them at the moment they are just numbers.
