Originally I had a problem and it got fixed after doing a check disk. Then I had to eventually format it. Before formatting, after I would shut off the fuze I eventually got a white screen, and had to force shutdown, then reconnect, then format.
I had some voice recordings on there. Once I formatted I could make new recordings. But the recordings that I tried to put back on the fuze added on the harddrive, but they won’t show on fuze. what’s wrong? Is that normal? Is there any way to get the recordings to show?
I already tried checking the disk again for errors.
I’m not sure this will help, but before I formatted the disk, the fuze would skip past recordings when it got to a certain number, and it would also save new recordings as ones before the skipped numbers. this is partially why I decided to format my fuze (besides the white screen).after shutdown)
