I tranfered music files to the sd, but sansa does not play them, It does hohu only, i have windows 2000, what is wrong?
What are the format are the Songs that you added to your SD card?
Actually just make sure they are MP3’s or WAV files and then they should play on your Sansa Shaker!
I tranfer them from windows media player, from real player, and also from itunes, but it does not work, the file i suppose it is wav
how i can see it? please
When you see the files in the Folders were they are located on your PC and you just try to drag and Drop them to the SD Card, are you receiving any error messages then?
Are the Songs purchased Songs from Napster, Rhapsody ect…?
When you right click on the songs and choose properties, what does it say as Format?
No, i did not received any error messages.
the are not purchsed, they are recorded by my computer when i play them on the web site.
formar is windows media player.
the sansa shaker does not support WMA it only supports music files in MP3 format.
