Whats the site for the downgrade then upgrade for Sansa M240Firm Wire 1xx to 4xx?
Anybody.
Message Edited by Timreck12 on 08-27-2008 12:28 PM
Anybody.
The firmware version levels (1xxx - 4xxx) are tied to the hardware levels of the main circuit board. If you change to a diffferent firmware level you will probably trash your player. I did mine and the procedure http://forums.sandisk.com/sansa/board/message?board.id=m200&thread.id=2128 for unfreezing didn’t work. I was able to reformat, but once disconnected from the PC, it wouldn’t power on.
For more information on this, see:
http://www.tnni.net/~walterjmoore/m250/facts.htm#e
A forum at
http://www.anythingbutipod.com/forum/showthread.php?t=3206
gives instructions on changing from European to US firmware and I used their procedure except chaged the level of the firmware. It went through the motions and installed version 2 firmware on a version 1 m220. It said it had the new firmware, but it won’t power on. You area working with an obsolete, primitive MP3 player so if you really need a feature that is only available via a new version of firmware, consider upgrading to a Clip.
