We just bought two sansa fuze players and a couple of preprogrammed slotradio cards. The cards work fine on one fuze, on the other it says “refreshing media” and the slot radio icon never appears on the player. I know it’s not the card because it works on the other one. Any advice? Thanks.
By any chance did you update with the new Firmware? When I did with mine I got the Slot Radio Option
Thank you! That did the trick!
You should mark Locojax’s post as the solution, not your own. After all, he or she is the one that gave you the solution.
