Hello im from argentina,i bought a sansa fuze about 3 months ago and yesterday my player dead without any warning,i just press the power button and nothing,ive tried to connect to the PC and there is no response,i leave it in a charge for a long time and still nothing,what can be the problem? i really want to have my sansa back to normal!Sorry for my bad english!
Have you tried holding the power switch up for about a minute?
Try resetting the player, slide the power switch all the way up for 1-2 minutes. Then try to power on the player. If there is still no responsed on the player. Try connecting it on your computer. If there is still no responsed then its a bad player and might need to be replaced. I would suggest contacting sandisk support
i have the same!!! PROBLEM!! im so sad!! the steps just dont work.
