I have a sansa e250 v1 and i put in a 1gb micro sd card in the slot. When I look for the songs that is in the micro sd card, it doesn’t appear in the music section.Any advice/help would be greatly appreciated.
Songs came from where and of what file format are they?
Device supports mp3 and wma.
Are you looking for a separate SD Card heading or something similar? You won’t find it.
Provided the songs on the card have valid ID3 tags, they will be sorted with all the other songs located in the player’s internal memory. 1 list for all songs, regardless of memory location.
If they are coming up under Unknown , then youy need to read this FAQ & fix your tags.
If they are coming up under Unknown , then you need to read this FAQ & fix your tags.
