Tried another computer, still same issue and same error message
Also my Sandisk is getting worse; it randomly freezes, it doesn’t play songs (shuffles through them on its own,) and it crashes to the point that even turning it off and on doesn’t fix it; frozen.
I’m using a PC and only Mp3 format (no itunes or otherwise.) I have my mp3 player covered in a protective case and it has never dropped in water/fell on the floor from a far area/etc. so I have no idea what the problem is.
Over time, adding and deleting songs can sometimes make the player go wonky. I’d make sure everything is backed up on your computer, and format it (from the Settings > System Settings menu). This clears the memory and optimizes the memory clusters, basically celaning it out like a good laxative.
This may help. If it doesn’t, all you’re out is the time it takes to re-load it. I’d try a few albums at a time and make sure there are no hiccups.
