Sansa converter wont let me import media?
it says i need a codec?
they are mpeg files.
It could be because my sound card busted, but i just want to make sure
thank you for any feedback :slight_smile:
I just checked and the videos play fine on my computer, just with no sound
Message Edited by xamandaxomg on 04-05-2008 07:30 AM
do you mean there’s no sound due to your sound card not working?.. Does your mobo have a built-in audio chip so you can see if the sound works in the file at all?
Normally if it’s saying it needs a codec, that means you didn’t install quicktime when prompted to during the initial installationÂ
