I bought a Clip+ 4GB player a few months ago. Now it will not turn off. The screen goes blank (power saver mode) after a few seconds like normal, but it keeps playing until the battery runs out. It appears the power button no longer works. I tried resetting it several times by holding the power button for 30 seconds plus, but nothing happens. Am I SOL?
Not if it’s only a few months old. First, try holding down the power button for longer, maybe even up to a munte or more and see if it will shut down. If not, it’s covered under SanDisk’s 1 year waranty.
Not if it’s only a few months old. First, try holding down the power button for longer, maybe even up to a minute or more and see if it will shut down. If not, it’s covered under SanDisk’s 1 year waranty.
I had the same problem - and my sansa clip is over a year old. I think that I did it myself - I was trying to add an audio book disc to the clip and it was refreshing - anyway, after exhausting internet research - and (after I purchased another one from Amazon), I was sitting here and decided to just hold the power button on until my finger got tired - GUESS WHAT, the little flower symbol that was on went out - I then turned it on again - and it began 'refreshing. Then IT WENT OUT AGAIN - with the little flower symbol. I shut it off again, by holding that on/off button - then it went out. I turned it back on and believe it or not, it is now writing the disk that I loaded in this morning. Go FIgure! I think I just asked TOO MUCH of the little thing. There is hope! Just persevere. I love my Sansa Clip.
