For “Region”, try North America (or Rest of The World). First, you may need to use the Restore command to reset the player…
For louder volume. try Settings -> System Settings -> Volume -> Normal. (seems to be the opposite of the Jam)
Try my personal choice setting for Equalizer -> Pop.
In my opinion, the noise-canceling earphones supplied with the Sport are pretty good. When I use them outdoors, I push the soft rubber tips a bit deeper into my ears to improve the noise cancelling and enrich the bass tones.
And just to verify, are you describing your problems with the Clip Sport or the Clip Jam ??
In my opinion, the round & hard ear buds that come with the Clip Jam have a low volume and fall out easily.
i.e. structurally are good and even better than previous ones. But software are very poooor.
If you use for audiobooks you can’t even add one bookmark!!!
There is problem with the number of files :0 We have 21 century and here you have limitations to 2000 or 4000 files :0
Sandisk SHAME ON YOU!!!
You can’t display actual hours on display.
Helpdesk told me, that is no problem, you can go to setings>time and then you can check current time. BUAHAHAHAHA.
Sandisk you produce very well mp3 players but your software is unacceptable.
In old mp3 players evryone could change/add rockbox - this is good software, veeery goood.
But in new sandisk mp3 players:
SanDisk Clip Sport Plus
SanDisk Clip Sport
SanDisk Clip Jam
unfortunately is no way to add rockbox and oryginal soft is veeeery poooor
Please release your IT programers (freeloaders) and e.g. take the rockbox soft to new mp3 players, it will be cheaper for you and better for customers and probably the sale will increase immediately.
