Sansa Clip+ Firmware Update 01.02.18
Sansa Clip+ Firmware | Instructions | Release Notes
Mac and Linux users can connect their Clip+ in MSC mode and follow the instructions below.
MSC mode instructions:
  • Turn on the Clip+
  • Navigate to "Settings" on the menu of the device itself
  • Next select "System Settings"
  • Next, navigate to "USB Mode" and select "MSC"
 Manual Firmware update
Firmware Download for All Regions - Click here to download
All languages are now in one firmware version. After firmware update you will need to select your Language and Region preference.
• Ensure your battery is > 50% full
• Extract the .zip file into a folder on your computer
• Once extracted, drag the Firmware file to the root directory of your Sansa Clip+
• Disconnect the Sansa Clip+ and let it begin the firmware update
• Once it finally finishes doing its update, it will turn itself off
• Turn the Clip+ on Select your language and region preference
• Once its back to the main menu, head to "Settings" > "System Settings" > "Info", and verify the "Version" is now 01.02.18
 Sansa Clip+ Firmware 01.02.18 Release Notes
This firmware has several bug fixes and enhancements, as listed below. Upon completion of firmware upgrade, the device will turn off.  Power on device to complete the upgrade process.  If device does not initiate or complete, press & hold the Power switch for 10 seconds to reset the device and then release and press again to restart.
Enhancements:
  • No new enhancement
Bugs Fixed:
  • Device hangs up after finished playing special mp3 files, which contain CRC error at the end of frames
KnownIssues:
  • Refresh database progress bar doesn’t scale with time
  • FM signal is weakened during FM recording
  • Powering off device is not available during Locked state
  • Some language strings are in English
  • Have to remove 200MB to allow enough space for DB rebuilding
  • Voice deletion in MSC mode doesn’t clean out filename
How do I update the firmware on a Sansa Clip+
SanDisk Clip+ problems!!
Firmware update problems
SD Card and Folders
Clip+ update 10218 problem with .flac files ?
Sansa Firmware Updater Fails to Install on my PC
Sansa Clip Firmware 01.01.35 & 02.01.35 Release
Transfering Playlists From Mediamonkey Problem - Clip+ 8Gb
Sanda Updater don't know my Clip+ anymore
Help with firmware upgrade/replacement
Sansa Clip+ Firmware Update 01.02.17
How can I tell how big an SD card I can use in my device.
Sansa Clip+ Frozen when returning to song list
My Clip+ boots then immediately says goodbye and quits
Cannot turn off/on - continously 'locked'
Volume not working after update
Just deleted Rockbox firmware and can't return to stock one [Clip +]
one song over and over
Podcasts are bleeding into each other
I just got a sansa clip+ and need help!
Recording Problem, both Radio and Voice
How to get to the menu
спалил прошивку заводскую и теперь мой sansa clip + 8gb как флешка мне служит как изменить это ?
Stop button not responding
Sansa Clip+ display is corrupt
stuck on 'refreshing your media'.
SansaClip+ funktioniert nicht mehr nach dem Firmware Update
After update new firmware Clip Plus is brick/dead Sansa
Sansa Firmware Thread
Empty recordings
Which firmware version for new unboxed Clip+
Text is missing
Settings menu disappeared
My Sansa won't turn on or off
Sansa Clip+ problems
Brand new Sansa Clip+ often restarts
SanDisk Clip+ acting crazy
Firmware update w/ rockbox installed
Sansa Clip+ with a mac HELP!!
Sansa Clip+ stays stuck on Sansa logo screen
Broken buttons on 2 different Sansa Clip+
Clip+ not recognised by Windows 7 any more but charges it?
Refreshing Media and reset settings
Enhancements:
Bugs Fixed:
I don’t know as 1 bug fix would qualify as “several”?!? :confounded:
:laughing:
Enhancements:
Bugs Fixed:
I don’t know as 1 bug fix would actually qualify as “several”?!?
That little quibble aside, this is an unexpected (but pleasant) surprise. I had assumed development for the Clip+ was deader than dead.
I wanted to check to see if my Clip+ needed updating, so I first downloaded the Sansa Updater.  It didn’t say there was new firmware available, just the manual.  However, the website said the latest version was 1.02.18, whereas I have 1.02.16A.  So, I went to the manual firmware installation page, and read through the directions.  It said at the end to go into the system information on the player and check that the firmware version is now 1.02.16.  I’m just wondering; is this a typo or do I actually have the latest version?  I just don’t want to accidentally brick my player or something.
When installing manually, _it is critical that the firmware file downloaded is unzipped or decompressed _prior to transfer to the Sansa.  Additionally, the file must be placed in the root directory, and not in any of the folders present.
When you unplug, the “firmware upgrade in progress” screen will appear.
There is a normal delay of a few days between posting the latest firmware builds here on the forum, and inclusion to the automated Sansa Updater.  If you have any problem installing manually, the Sansa Updater will transfer and decompress the file automatically for you, a few days after the initial release.
Bob  :smileyvery-happy:
01/02/16 version radio feature removal was performed by changing the last letter in the file name from A to G,
How do I perform the act of removing the radio in the current version (01.02.18)?.
just remove the v010218 and replace it with a G
I sent an email to the admin. they will update the file soon so it is as it normally would be clppa.bin
I’m trying to install the update on my clip. The updater tells me same ase OLEDCRT. I tried the manual download.
I clicked on it & it wanted to extract w/winzip. They’re telling me it’s not free anymore. I tried downloading 7 zip (c-net says it’s great & can open all zip files).
It extracted it into my vlc program & msg says that’s not an option w/that program.
Is there some way I can extract this file w/o having to purchase winzip
I tried to rename the file to clppg.bin, and copy it to the device (MSC through and through auto detect) and it failed to remove the radio. I turned to for support and they had a solution, if someone could help me I would appreciate it.
Thank you.
Thank you.
just tried it and it looks like that does not work with this firmware. you will need to downgrade to .16 if you want to remove the FM radio. link to .16 below
http://forums.sandisk.com/t5/Sansa-Clip-Sansa-Clip/Sansa-Clip-Firmware-Update-01-02-16/m-p/150227/highlight/true#M31277
Just a note that after updating my volume was reset to what I assume is factory default.  After changing I’m thinking it’s still a bit on the low side.  It’s still plenty loud enough through the head phones, I just have to turn it up to “11” when I use it in the car stereo thru an adapter.
It’s probably the EU volume cap. Read this:
http://forums.sandisk.com/t5/Sansa-Clip-Sansa-Clip/No-more-High-setting-in-music-volume/m-p/143082/highlight/true#M32400
hello there,
since implementing this last update i have noticed that performance has become a little sluggish, however this is not a huge problem.
a problamatic issue has also arisen; when locking the clip+, i find that the device is crashing after a few seconds - playback ceases and i have to wait a while until it becomes usable again. this is a little annoying, as it meant that i have to refrain from locking the device and experience the issues associated with that…
is this a known issue?
i have the 8gb vesion, with 8gb memory card, with over 250mb free internally and externally.
any advice or a remedy would be appreciated.
thanks,
dan
I thought I could throw away my Sansa Clip + it was completed locked by updating the database but happy enough there is firmware 01.02.18.
The manual update gave my a new Sansa Clip + .
Thanks
I did updating of my Sansa Clip + for version 01.02.18, but I’m having some problems: It restarts when it’s playing FLAC files.
Wow !
Finally !!!
I was having nightmare because of this “freaky frozen thing” with my clip+ !!!
I did everything, format, reformat, I even got some software to remove ID TAG from mp3,
anyhow !!! This is the best !!! No problem anymore !
worked for me !
@arjang wrote:
Wow !
Finally !!!
I
worked for me !
“What” worked for you??? :confounded:
I have so many mp3s which I couldnt play because It was cause of freezing/hanging the sandisk !
now I tested all of them and Im happy !
what was your problem ?
