hello,
When my Sansa clip is connected on my USB , the display of sansa clip is not on (black)
thank you
Georges974
hello,
thank you
Georges974
Try to hold the power switch up for 15 seconds to do a soft reset. Plug the Clip back into the computer. If it continues to not light up, then you will need to contact Support and request an RMA.
Go Sansa!
