So I got this Sansa Clip+ for Christmas with the desire to get a 32gb microsd card for 40gb of storage space. I then Rockboxed the Clip+ for the ability to play FLAC files. All went well with the Roxkbox and I have been using it with my 8gb full. So I bought a Sandisk 32gb microsdhc class 6 card so i could add more files. Well when I first put the disk in I had trouble and got an error. When I tried to transfer getting an error that said could not read the source disk. So I formated the microsd with windows, that took forever. Now I am able to transfer files fine, I even check that the files are on the disk before I disconnect. Now when I go to select the file from the files->microSD1 in rockbox there is nothing there but the file folder. Some of the albums did transfer just fine, but if I erase them and try to transfer them they do what I mentioned above. I then plug the Clip+ back into the PC and the album I just copied is no longer there. The file folder is the only thing that remained and the memory of the microsd is smaller by the volume of the album, by this I mean the album is on there I just can not see it any more all I can see the folder. All the FLAC files that were transfered are now not visible but are still on the disk because the space is still taken up. I can not seem to get this to work correctly.
I formatted using windows explorer. I have the Clip+ in USB mode MSC, so I can see the Clip+ as a drive and the Microsd card. I did a right click then format. I formatted to FAT 32 and left the allocation size as Default Allocation size.
What am I doing wrong?
