Sansa C250 & SMC.
I have a Sansa C250 & I also bought a Kingston 2gb MicroSD card with an SD Adapter.
I have a couple of problems.
  1. Sansa Media Converter doesn’t detect the MicroSD card at all. It says no device.
  2. If I put mp3 files on the MicroSD manually via my card reader the sansa c250 won’t read the id3 tags
    and will show all the files on the microsd as unknown artist - unknown album, etc.
To say the least I’m pretty dissapointed. However, I’m sure this can be fixed?
Do you have the C200 V2? or the first version. If you still have the ability to choose between MTP, and MSC mode. Select mtp and see if that works for you. Also try to use windows media player in mtp mode and see if the MicroSD card will show
