Hi, Happy holiday’s, anyways have the Sansa 4G and bought a 8GB card to add to the Sansa my PC sees it as 12GB but unable to get my Library which is holding lets say 400 songs and my Sansa only has 300 songs, my PC say’s that there is no more room on the Sansa yet the PC reads it as 12? What is the culprit?
Thanks
Sounds like you’re trying the use the most confusing, biggest problem-maker, bar none we hear of on this forum, Windows Media Player. Why not just drag & drop the files you want from your computer to your player and avoid all the nonsense?
That way you are in control: you can do what you want.
That way you are in control; you can do what you want.
Ha, ha Tapeworm that’s to easyway out but you are right.
