I just buy an Ultra USB 3.0 Flash Drive and every time I put it in the PC goes to BSOD. I need help, I try a couple of things (elemental) but no good luck so far. I cant used.
The BSOD have this message “SYSTEM_THREAD_EXCEPTION_NOT_HANDLED”
Another possibility, if you have never used a USB 3.0 drive before and your pc does support USB 3.0 it is possible the pc’s USB port’s contacts are oxidized and not connecting to the USB drive. Cleaning them with emery paper may help.
