SanDisk Ultra SDHC Card - 16GB
Hi there,
I just bought a SanDisk Ultra SDHC 16GB card but am currently having some qualms about it. Should I be worried if the back of the card states “Made in China” but the back of the SD card itself says “Made in Taiwan”?
Also, the printing on the front of the card itself looks more faded that I THINK it should too.
I’m currently running the H2testw but I know that won’t tell me if it’s genuine, only if it’s working as it should, but yeah, should I be worried that I bought fakes?
Please advise. Thanks!
to be sure that you bought original cards i suggest contacting the sandisk support.
you can contact them through this link
http://www.sandisk.com/about-sandisk/contact-us/
