Hi All,
I bought on Amazon 6:
SanDisk
Ultra-Dual Drive
Go 64GB
for USB Type-C devices an A Connections.
Up To 150MB/S
I am running windows 10 and 11 on my PCs.
I can not get these flash drives to go any faster than 38 MB/s
I wasted loads of time researching what the problem was.
I tried the Flash drives on a Linux Mint O/S
It was absolutely flying on there
200 MB/s
And it’s rated at 150MB/s.
I also inserted another Flash Drive, A Sandisk Extreme usb 3
and that did a write speed of 170 MB/s .
So there is nothing wrong with my PC !!
Anyway, to cut a long story that’s it!
How do I get these drives to deliver their advertised speed?
Do I need to download a drive?
Or just send them back to Amazon
For a refund?
If the drives work fine with Linux but not with Windows it seems the problem is not with the drives. Your Mint probably doesn’t have an AV running and the flash drive isn’t configured for safe removal like it is in Windows. Tweak your Windows settings then try it.
Thank you, for your advise, ed_p
I did try setting the settings in windows
Device Manager> Disk drives> USB SanDisk>Properties>Policies> Set at Best Performance
this did not make any difference.
There is an update to when I last posted.
under the same test conditions I removed the “SanDisk
Ultra-Dual Drive Go 64GB”
and inserted a USB 3 Corsair Voyager GTX
and got the speed I would expect from it.
I then removed that USB and inserted a “Sandisk Extreme USB 3”
and got the speed I would expect.
So, I would say categorially that windows 10 and windows 11
have a compatibility problem with only the “SanDisk Ultra-Dual Drive”
I did use CrystalDiskMark to do my tests, as well as using windows explorer!!
I am not sure where to take it from here?
Any other suggestions are most welcome?
I would rather fix the problem,
if I can, rather than return the USB 3 sticks to Amazon
for a refund.
Thank You…
I’m having similar issues with my Sandisk Extreme Pro 512Gb and new 1Tb keys !. Write speed initially around 200Mb/s but quickly drop to 80-100 Mb/s which is unnaceptable. Tried NTFS and ExFAT formats to no avail, rebooted PC etc. Using a high end Intel PC with USB3 ‘SS-10’ port. If I run something like AS-SSD benchmark tool I can see speeds in the region of 400Mb/s yet when I transfer a file (from a very fast M2 drive) it’s a different story. Yes latest drivers and Win10 updates applied.
Turn off your Windows security apps. They are reading and validating every byte being written.
Hello, I have three sandisk ultra “dual drive” type-c/type-a drives.
Two where bought today, and 1 was bought about 2 years ago.
These are 128 GB in size. They are advertised as “Up to 150 MB’sec”
Old drive on the left, and new ones on the right.
As you can see, the speed is a LOT worse on the new revision drives. It still manages “154/155 MB’sec” on 1 form of sequential write. But is less than half the speed vs the old revision drive on some read/write operations.
Thats a really good question that warrants a response! Did Sandisk address your concerns?
