Drive shows up as 2 Drives in Windows but U3 drive appears as CD drive and the data partition says it needs to be formatted.
Drive Properties show File System as RAW and 0 Used 0 Free .
I NEED the data off of this drive
I have tried numerous Recovery Utilities and nothing can find my files. Knoppix and every other utility out there struck out. What Next? Need these files
Try a QUICK format of the drive and then run the recovery utilities for it.
And in the future make sure you have backups for you important files.
