Hello!
I couldn’t find the correct forum for my MP3 player… ( It’s rather old, but I do love it. ) … so I apologize if I did not see the correct forum.
My SanDisk 1024R (Model Number SDMX1) is currently giving me a hard time after years of working quite well. One day while playing, it simply decides to freeze up. I remove the battery in it, attempt to reload, and all the player wishes to do is stay at the hourglass loading screen. I’ve attempted to wait 30+ seconds for it to load… no luck. I’ve also removed the battery and let it sit for an hour. I cannot access any of my MP3 files through the computer to reformat it due to the fact it stays on the “I"m loading” hourglass mode even when I use the USB cable to connect to the computer…
Any idea’s? Thank you.
I am having the same problem. Nothing’s working (battery removal, reformatting, etc.) Can someone help us out? I’m not ready to figure out what to upgrade to yet!
I have same device know how to fix SdMX1 256Mb, 512Mb,1Gb
mark issue thread as [SOLVED]
Leave board open for thanks. Ty
Simply move the slider to the inner (right) selection to unlock keys and press play/power till turns on indicated by screen display hourglass.
If this doesn’t work try moving the slider from each locked and unlocked positions a few times and tray again, it may have had a stuck granule of infiltration+al debris orelse: for each do call procedure forrepair textured sandy moisture within the switch or body dusties from within itself preventing proper boot up, just clean with a chemical solvent wearing gloves and eyewear safety protection and wipe cleansed dry and allow to fully dry and return to working before retest
/Done
SD935Pro
