Got my new sansa clip+ out of the box and I am not able to make the FM radio work. Battery is charged. All I get on the screen is a set of headphones and “music”. I don’t expect it to play any music because I haven’t loaded any yet but I would expect to be able to get to the FM Radio but can’t seem to make that happen. Any suggestions on how I make that happen? Thank you.
Please note that I do not see a menu of items to select from on the MP3 player. I do not see a “lock” or “unlock” .
My computer recognizes the player as a new piece of hardware.
The player is not recognizing the software on the CD when I put the CD into the computer.
The player does not allow me to pull the software over to what I t hink is the “root directory” for the player. I am guessing tha the “root directory” is the “Sansa Clip+ 4GB” or the “Internal Memory”. It won’t allow me to copy into either of these. Comes up as:
Sansa Clip+ 4GB
- Internal Memory
+ Albums
+ Audio Books
+ Music
+ Playlists
+ Podcasts
+ Records
+ Service
My D Drive that reads the CD has these files on it:
autorun.inf and sansa-installer.exe and another folder that reads:
fscommand with these files on it: dloadrhap.exe , dloadrhap.txt , proxy.bat , proxy.exe
If I don’t need any of these, please let me know. I don’t want any more stuff then I need to run the player.
I am assuming that I only need hte autorun.inf and the sansa-installer.exe files.
I don’t understand what Rhapsody is or why I need it.
Did you peel off the sticker that covers the display window? There should be a small tab to help peel it off. Also there should be some songs already loaded for samples.When you see the real window scrolldown to FM radio. Good luck.
OK … removing the sticky film did help. And I feel like an ■■■■■. But I am still going to ask the next question:
I am not seeing the settings … and I think the language is German. How do I get to an English settings menu.
Thank you
Bonnie
I did the manual load of the most current version of software and that has fixed the language issue so I am good to go. Everything is working now. Thanks for all the help. Bye.
Glad that helped. Now, even if it is in German, you can still navigate to settings. Press Home button to see the menu. Music should look almost the same (Musik). Look for Einstellungen (? I think). It should be the next choice on the menu up from music. Press the center button to choose settings(Einstellungen), then select Systemeinstellungen (system settings), then Sprache (language), then English. Hope that works for you. (I used to teach Spanish, but German is not my forte.)
Hello and thanks to all who provided comments and feedback. Everything is now working exactly as I would expect and I’m very happy with my little MP3. Bye. Bonnie
You are laughing about the volume, but I can’t get my volume to go LOW enough. I have a playlist of songs to help me sleep and I turn the player down as far as it will go without the sound turning off and it’s still too loud :( Is there anything I can do? I had been playing these same songs on another device and could turn the volume down a lot more than on this one. (I have the Sansa clip zip 4 mg)
Also, where is a page that tells you how to get songs into your playlist? I’m having a heck of a time adding songs. I drag the song to the music folder, then to the playlist folder. It shows the song in the playlist I want, but when I disconnect the device from my computer and try to use it, it does not show the new song listed in my sleep playlist. It is there in the music though.
That’s a new one. Usually, people post about not having a high enough volume. lol
I don’t have a Clip Zip, but the settings should be the same as in the clip+. In the player’s settings -> system settings -> volume, is it set to “normal” instead of “high”? If not, then set it to “normal” and see if you can then set the volume low enough to your liking.
The only other thing that I can think of is to buy earphones that have a volume control or just a volume control adapter for earphones that you already have. The volume control on earphones can lower the volume already set on the player, but cannot raise it beyond that.
Peel the protective sticker off the face of the unit.
Read the manual.
When the player freezes up or acts wonky, perform a reset.
If you have problems, go back and re-read the manual.
If you still have problems, post a new message here.
Sandisk should just add in an insert that tells people in big bold red letters to remove the screen protector before using the player for the first time.
So glad to be of some help. I read this forum before I started using my new player because I also bought a player for a friend who has some trouble with the English language and wanted to be able to explain/solve problems, etc. When I first read about the sticker having to be peeled off I was surprised. When I actually tried to peel it off, it was a chore. That thing really stuck.
I’m so grateful to all the great advice that helped me get started. A sticky for newbies would be wonderful. As Christmas/Hannaka/Kwanza gets here, there might be a lot more users with simple questions.
You are laughing about the volume, but I can’t get my volume to go LOW enough. I have a playlist of songs to help me sleep and I turn the player down as far as it will go without the sound turning off and it’s still too loud :( Is there anything I can do? I had been playing these same songs on another device and could turn the volume down a lot more than on this one. ( I have the Sansa clip zip 4 mg )
Firstly this board is for the (original) Clip and Clip+ and this thread is discussing the Clip+. You should have really posted your query in the Clip Zip board to avoid confusion and keep things on-topic.
But have you updated the firmware? The Zip as well as its predecessor, the Clip+ exhibited this volume issue when first released. I believe the original Clip did too. SanDisk added more lower volume steps for each player as this became known via firmware updates.
If you update to the latest firmware, this and any other improvements will be added to your player.
Mine (the Koss cable) came (from Amazon) with an L-shaped plug, although I’ve read that some people have received a straight plug. The description says an L-shaped plug–think you could order it and then if a straight plug comes, call Amazon to take it back as not as advertised.
I could do that, but I don’t want to have to possibly go through the hassle. I just dug out from the back of a drawer an old pair of earphones that has a volume control and use those.
