Hello there,
Just a quick question.
Does SanDisk PRO DUO 32GB cards works on a PSP 3000 ?
Some customers asked me about full compatibility or possible reading errors if using a 32Gb pro duo card in a PSP 3000 console.
According to the SanDisk compatibility tool PSP is compatible with all produo cards:
http://pct1.sandisk.com/ProductList.aspx?DeviceID=1506
I have checked the Sony PSP Support and points and says " The PSPgo / PSP system is compatible with any capacity Memory Stick media as long as it carries the Memory Stick logo
Any owner of a SanDisk PRODUO 32GB in a PSP 3000 can confirm please?
Obviously the SanDisk official response will be appreciated ![]()
Thanks in advance!
