sandisk flash drive
So I made this linux live usb and I’m having trooble returning it to being a regular storage drive. I’m using windows 7, by using compmgmt.msc I can see the drive but I can’t format it. usually when right clicking you can format but here I can only click on “help”, chich does not help by the way.
what could I do?
Did you check with the forum of the app you used to make your live linux usb drive?  They should know what their app does and how to fix the problem.
You probably need to delete the partition on the flash drive, reallocate it and format it.
@ed_p wrote:
Did you check with the forum of the app you used to make your live linux usb drive?  They should know what their app does and how to fix the problem. Talk To Sonic
Thanks for this idea let me do this.
You added a SPAM link to the quote of my posting!!!  Nice approach SPAMMER.
