Hi all,
The technical specs say that the Sandisk Extreme Pro was compatible with Windows 10. I tried mine now in 5 different Windows 10 computers and neither was able to use it. It is seen in the hardware and I can see the partition also in the administration, but Windows does not assign a drive letter to it and won’t let me do that manually.
Putting it back to any Windows 7, Vista or XP system it workes flawlessly again.
My problem now: Even if there was a way to get it usable in my own Windows 10 box: I a work a lot at customer sites and used the stick to have my own software available. Obviously, I cannot manipulate around on their computers. So I need a stick that works without installing software or other maipulation of the PC. This used to work wherever I go before Windows 10. My two spare sticks, one Intenseo and one Lexar show, no problems on any of these PCs. This could be either because they are a different brand or because they are 64 and 32 GB sticks and this is 128GB.
So now the question: Is there any way, maybe by re-formatting or re-partitioning under Windows 7 or Linux, to bring the device into a state where it works with Windows 10?
Thanks
I didn’t find the right solution from the internet.
References:
http:forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/Sandisk-Extreme-Pro-128GB-USB-3-0-stick-not-working-under/td-p/355075
