Does anyone tried to run Windows 8.1 on this pendrive? Complete installation, don’t want usb boot for installation.
I need a Windows 8.1 portable on this pendrive.
Regards
Regards
Well, SanDisk stopped making Windows 8 to Go drives a yr or more ago but some distributors still have some of the old ones in stock so to answer your question, Maybe.
Look for a drive that has Windows 8 to Go on the packaging.
By default, what I know is that USB flash drives are not bootable. You need to configure this first. Check Unetbootin as it’s the utility to do this, plus, it’s free. ![]()
Hi Ed_P, did those actually say Windows 8 to Go on the packaging? Or was it Windows 8 compatible, or Windows 8 certified? Do you have a photo of the packaging you could share? I’m after one of those myself as well. Thanks.
Sorry Nazgul I can’t help you. I recommend you buy a brand that Microsoft has certified:
http://technet.microsoft.com/library/hh831833.aspx#wtg_hardware
