On my Sandisk Extreme 2Tb USB drive I tried out the “better performance” setting for testing, but now cannot re-enable “quick removal” - and I often cannot remove the USB drive (eject) until I power down the entire laptop. Any suggestions how to fix this under Win 11?
Encountering issues with my SanDisk Extreme 2TB USB drive on Windows 11, I experimented with the “better performance” setting, leading to difficulties reverting to “quick removal.” Consequently, ejecting the USB drive became problematic, often requiring a full laptop shutdown. During my search for a solution, I stumbled upon a helpful EaseUS giveaway. SanDisk Extreme SSD Failure: Tips to Prevent from Further Damage
For those facing similar challenges, I recommend checking out the EaseUS giveaway, as it may provide insights and tools to address USB drive configuration issues on Windows 11
