SanDisk Cruzer memory stick 4GB
In order to transfer a file from one computer to the other, I downloaded it on a SanDisk Cruzer memory stick. Then I stuck it into a USB port of the other computer.
Left-clicking it, gets no reaction; right-clicking it, gets a menu which prominently shows  “Run U3 Launchpad”. That reacts to neither left or right-clicking. So I clicked “Open” (another option of the Menu), which shows 3 possibilities: 1) autorun.inf; 2) launchpad.zip; launchU3.exe.
  1. opens a Notepad windows; 2) opens a long list that I have no idea what to do with; 3) opens a window with, on the left, U3Smart Program, and, on the right, another 7 options.
This all is way too complicated. I just want to copy a file onto the stick, and then copy it from the stick to another computer. Can I do that, and how?
in that i suggest formating the drive and delete the U3 software in order to use the drive as a normal storage device.
if you already installed the U3 software, then you can run the removal tool and delete it from the drive.
http://kb.sandisk.com/app/answers/detail/a_id/2550/kw/u3
Thank you - it worked!
this is wonderful!!!
