Description: [H:]USB Mass Storage Device(SanDisk Cruzer Dial)
Device Type:??Mass Storage Device
Protocal Version: USB 2.10 ← Hint: This device can run faster when plugged to a USB3.0 port
Current Speed: High Speed
Max Current: 224mA
USB Device ID: VID = 0781 PID = 5599
Serial Number: 4C531001580105114184
Device Vendor: SanDisk
Device Name: Cruzer Dial
Device Revision: 0100
Manufacturer: SanDisk
Product Model: Cruzer Dial
Product Revision: 1.00
can i get fremware and the program for this flash stick please
nico
September 17, 2021, 1:31am
2
xXAndrewXx:
Sandisk uses its own microcontroller so you cannot program it. You can try chipgenius with other brands surely they use SMI, Phison, etc.
can i get U3 cruzer download link ??
ed_p
September 21, 2021, 10:38pm
4
This link should answer your question.
The U3.com website seems to be down. Anyone know what’s the status?
Will SanDisk continue support of the cruzer flash drives with the U3 platform?
Thanks!
MarkB1
September 21, 2021, 11:14pm
5
The capacity on my scan disk Crazer Glide USB 2.0 64 gig capacity. Currently the flash drive is showing 61.97 GB Total capacity with Available space of 36.05 GB (95.2 MB purgeable). There is NOTHING on the flash drive in question and yet it says the following 26,014,056,448 bytes (26.01 GB on disk). I am using an iMac. Any answers?
the problem is that usb stick is write protected
and i tried a lots of methods to unlock it or format it and it didn’t work
