i also want to know about this error because i am facing this issue again and again.
regards
regards
i am also having the same issue and still dont get a solution for that plz help
Customer Care Support- Toll Free Number’s, Email Id, Complaint Helpline Number’s
Sia Jewellery Customer Care Helpline Number, Complaint Email Id, Office Address
Tata Sky Dish TV 24×7 Customer Care Toll Free Number, Office Address & Email Id
here’s the perfect solution.
throw it in the trash, make sure its in the non combustible.
go buy a new flash drive, best on the market right now is kingston or samsung
and for that other jackass that said, i hope your new brand has a more generous return policy;
you wont even be needing a return policy because, it wont really need replacing. whereas with this WONDERFUL company, you’ll need to call in for a replacement every other day, and lose whatever you hadn’t backed up.
btw: isnt backing up the point of flash drives? if you back up a pc files to a flash drive, then back up the flash drive to your pc… yeah that makes as much sense as sandisk themselves do, lol.
other creative activites you can perform with this WONDERFUL product is;
Sandisk; when you feel like your life is too easy, buy a flash drive from us ![]()
we will help you appreciate the better things in life, like kingston.![]()
Who cares if he will get banned by a company which somehow manages to manufacture fricken DEAD ON ARRIVAL product when its manufacture process became mature TEN YEARS AGO!
First time I connect this drive and it’s ALREADY broken! What the fruck?!!
I am also facing same issue please help me any one Customer Care & Toll Free Number
Found at Toms Hardware:
Click on ‘Start’ –> ‘Run’ –> type in ‘regedit’ and press enter.
Search for HKEY_LOCAL_MACHINE
Scroll down the list and click on SYSTEM
Click on CurrentControlSet
Click on Policies
Click on Microsoft
Click on FVE
In the panel on the right side, if the values for either FDVDenyWriteAccess OR RDVDenyWriteAccess are anything other than ‘0x00000000 (0)’, right click and then click on ‘Modify’, then enter ‘0’ and press Enter.
Remove the flash drive and reinsert. You can now copy to or write to the flash drive.
Works for Windows 7 Professional SP-1 64-bit
Find the wedding dress of your dreams by browsing thousands of dresses in popular styles. In wedding dress gallery, you can search by and view a-line, ball gown, mermaid, and sheath wedding dresses. For more…
Please visit Rakhi Images
Please visit <Rakhi Images
Please visit <a href= "http://www.dooiitt.com/beautiful-relationship-rakhi-images/">Rakhi Images</a>
Afternoon _ Tapeworm: _
_ _ I too, learned 'the hard way" as you did about the limitation of FAT32. There is one soulution, albeit a rather extreme one. If your familiar with partitioning a drive, then you could partition your drive in to 4 partions. You’d lose just a bit of memory space due to the partitions, but would be able to use the greatest part of the drive as opposed to just slightly less and 4 Gb. Just a thought. The alternative would be to format the drive in NTFS; which doesn’t limit file sizes.
Stay Sharp:
_
Rick _
my 32gb won’t let me have a password
Why?
On the side of the drive there is a little switch. Move it in the opposite direction and then try it.
Hello forum, i create an account just to tell my story
maybe I have the ULTIMATE and FINAL solution to this ugly problem hehe
try like 10 methods around the web and this forum to solve this problem
some of them work for some people, but not for the most
Hope that this method work for everybody
it works for sandisk glide 32gb 3.0 and the cruzer blade 16gb checked by myself
THE SOLUTION WAS FORMAT THE PENDRIVE IN A LINUX ENVIROMENT.
i spend several hours trying to format the cruzer16gb with no success
and give to my neighbor the 32gb glide one, 5 minutes later he knock my door and told me its done!
I use linux since ubuntu4.0 now i consider myself an advanced linux user…
I cannot write by any method on the cruzer force 32 gb.
I tried gparted . dd and fdisk…
@kbsound: if you know a working method in the linux enviroment, please consider to share.
thanks in advance.
If the drive doesn’t work return it for a replacement, either the place where you bought it or to SanDisk.
Open command prompt window and execute these commands in this order:
Exit after it’s done, remove the stick from USB and plug it again.
Thanks & Regards,
Tom,
I would never recommend a journaling file system for a flash drive. FAT or exFAT only.
I love this post. Thanks for starting it. I had the same issue but reading all the replies helped me a lot. I’m glad. ![]()
Thanks,
