If the disk says ‘write protected’ using Dos how can you do ’ clean’ or any other command.
Я использовал USB-накопитель, чтобы создать диск резервного копирования / восстановления для моего ноутбука.
Я не понимал, что ноутбук переформатирует диск в меньший размер.
Когда я закончил использовать его для восстановления, я попытался использовать для резервного копирования данных и найти меньший размер.
@lounvre wrote:
Check your sd card if it is a FAT32 format drive, then manage your disk management by going to Start menu, right click My Computer, click Manage and look for Disk Management. You can see there the drive of your SD card showing FAT32, right click the SD card drive and format (make sure you backup your files). Change FAT32 format to NTFS, thick quick format and wait when its done. That’s it, you now have a working SD card. Good luck!
I think the problem may be OS dependent. Try running the cruzer blade within XP. I found it to work when I did but when I went over to Win 7 and higher I had problems. I have this theory there may be a virus causing it.
@britany wrote:
@lounvre wrote:
Check your sd card if it is a FAT32 format drive, then manage your d audacity temp mail origin isk management by going to Start menu, right click My Computer, click Manage and look for Disk Management. You can see there the drive of your SD card showing FAT32, right click the SD card drive and format (make sure you backup your files). Change FAT32 format to NTFS, thick quick format and wait when its done. That’s it, you now have a working SD card. Good luck!
I wonder if there exists any XP systems any more? That was an OS 20 yrs ago, hasn’t been supported in over a decade, and the hardware it was on has to be all dead at this point.
