Is There anymore Firmware updates for this mp3 player. iam having bug issues.
Whenever there are firmware updates, they are posted here (usually before anywhere else). If you don’t see any new f/w updates posted here, you can safely assume there aren’t any. You can stop asking.
Dear Sirs I am a new SanDisk Clip Sport but i don’t know if the firmware is updated; I tried to download sansa updater but when i confirm to accept terms and conditions i haven’t possibility to continua.
can help me?
Thanks and regards
You can verify the installed firmware version on your player by heading to “Settings” - “System Settings” - “Info” in the menu and verify “Version”.
If the firmware version is older than 1.27 you might want to update . If so, use the manual firmware update method instead of Sansa Firmware Update. Se the “Manual Firmware Update (Download and Instructions)” section in the first post here for instructions:
Sorry for the old link in my earlier post above. This is the latest firmware:
If the firmware version is older than 1.27 you might want to update . If so, use the manual firmware update method instead of Sansa Firmware Update. Se the first post here for instructions:
