i have a sandisk clip sport and when i try to play a AAC File Format my MP3 player frezzes on me
can there be another upgrade to fix this i need help.
You could try installing the latest firmware.
How long is the file you are attempting to play?
I was trying to play a 4minute.57second song
Also the new firmware version 1.25 gives an error that says
“No files found” under music
Is there another firmware update to fix this
Hi panda1212,
You can download and install the firmware version SanDisk Clip Sport Firmware 1.22 again on the Sansa Clipsport MP3 player and check if it resolves your issue:
