I bought a new clip and I love it, but there is one thing that annoys me. I like to create playlists in “My Music” folders, not in Windows Media Player, for the the gym—Rock folder, mellow folder, etc. In my old player, it would honor that and I could listen to each folder the way I wanted to. With the clip, it is too smart for its own good. It reorganizes my folder by artist and album and I have to now search for each song on the player when all I want is to listen to my rock or mellow folder. Am I missing something?
Michael
I have upgraded the firmware to V01.01.18A
Message Edited by verytallmichael on 01-11-2008 08:58 AM
When you say “create playlists”, do you really mean playlists, or do you mean subfolders?
The Clip currently displays songs sorted by tags, not by folders within memory. If you meant playlists, you can still access your playlists within the Clip and have the songs sorted in order within the playlist, assuming you’ve created the playlist correctly.
Message Edited by PromisedPlanet on 01-11-2008 01:05 PM
I mean subfolders that had songs in the order that I wanted. It used to be so easy. Now I have to find the song, and if it’s the only song from an artist, it just repeats itself. The other thing is, let’s take The Greatest Hits of Eric Clapton. I can’t listen to the whole album in order because the clip organizes into all of the bands he has been in–Cream, Blind Faith, Yardbirds, etc. How to I play things the way I drop and drag them?
Unless and until Sansa allows a folder view, you can’t do what you want, unfortunately, apart from: using a playlist; or changing the ID3 tags.
