My apologies, however I could not find the proper forum to post this problem and I thought someone here might be able to provide some knowledge leading to a solution. I recently purchased Sandisk SSD part number SDPA3AD-016G and the ebay seller listed it as working with Dell D430 laptop. It has the proper connection (ZIF) and fits, however the Dell BIOS does not recognize this drive. HELP! Thanks,
you dont need multiple threads for one issue.
as said in your other thread. the product you refer to is an OEM only product and is supported by the Host manufacturer only. you will need to contact Dell.
